December 18, 2021 at 5:30 amShantanuG23Subscriber
I want to bring to your attention a problem that I am facing and request you to help me troubleshoot it.Â
I am running a Sector-combustion study on Ansys Forte for a 1-cylinder diesel engine. Chemkin Pro files need to be imported in the Chemistry model (Model ->Chemistry) to simulate fuel combustion.Â
On running the Chemkin preprocessor on the Chemkin Pro files on Ansys 21, it fails and displays an error. When the preprocessor is run on Ansys 17, it runs fine and executes properly. I have tried all the solutions I was aware of, yet the files do not pass the preprocessor. What could possibly be the problem? I am attaching the files for your perusal. Please let me know if any other information is required. I would be happy to provide the same.Â
December 22, 2021 at 9:33 pmRKAnsys EmployeeHello,
As Ansys engineers, we will not be able to download any files. Can you please insert an image instead? Thanks.
Viewing 1 reply thread- The topic ‘Chemkin Pro pre-processor issue’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Non-Intersected faces found for matching interface periodic-walls
- Script error Code: 800a000d
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- error udf
- Diesel with Ammonia/Hydrogen blend combustion
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
Top Contributors-
1341
591
589
525
366
