TAGGED: beam, bolted-connection, mechanical, object-generator, structural
May 16, 2022 at 5:58 pmaveragej03Subscriber
I have a model that has many bolted joints and object generator was a huge help when making the beam connections. However, when I go to use object generator to add pretension to these beam connections, it won't let me use it when the "scoping method" is "beam connection".
May 17, 2022 at 12:10 pmAniketForum Moderatoryou can try to do this with ACT, which would require python programming:
First try and see if these APIs are recorded:
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v221/en/act_script/mech_script_record.html
-Aniket
Viewing 1 reply thread- The topic ‘Can you use Object Generator to apply pretension to Beam Connections?’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- How to apply Compression-only Support?
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- Geometric stiffness matrix for solid elements
- Script Error Code:800a000d
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- Elastic limit load, Elastic-plastic limit load
- Element has excessive thickness change, distortion, is turning inside out
Top Contributors-
1727
630
599
591
366
