October 19, 2023 at 12:09 pmlouiee1907Subscriber
I did a random PSD vibration analysis in nCode. I applied as duty cycle for X-Y-Z directions as 1790 repeats(X=1790,Y=1790,Z=1790) and exposure time is 1 sec.Â
My life calculated is 1.3473E2 repeats. I know the life is short but how can I convert life to hours?Â
Please I really need your helps
October 20, 2023 at 1:07 pmAshish KhemkaForum Moderator
Hi Louie,
I think you have asked the same query here and will close this topic.
Fatigue Life Result (ansys.com)
Ashish Khemka
- The topic ‘Calculating Life to Hours in nCode(Please Help Me)’ is closed to new replies.
Ansys Innovation Space
- Ayuda con Error: “Unable to access the source: EngineeringData”
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- How to select the interface delamination surface of a laminate?
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- Frictional No separation contact
- Elastic limit load, Elastic-plastic limit load
591
544
524
366
