June 13, 2023 at 6:51 pmMarkéta MilerováSubscriber
I've been experimenting with a 6DOF and overset method to simulate a flow around an oscillating cylinder. The simulation works fine when 6DOF is off and movement is explicitly defined. But when I switch to 6DOF (with 1DOF rotational motion) the mesh with the cylinder starts to shrink, even when deformation is not defined. Could this possibly be a bug in Fluent?
June 14, 2023 at 10:24 amSRPAnsys Employee
Please ensure smoothing and remeshing is turned on. Please see the tutorial at the link below for more details.Â
Thank you.
- The topic ‘BUG: overset method with 6DOF’ is closed to new replies.
Ansys Innovation Space
- Non-Intersected faces found for matching interface periodic-walls
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- UDF, Fluent: Access count of iterations for “Steady Statistics”
- RIBBON WINDOW DISAPPEARED
599
591
565
366
