AXI-SYMMETRIC DOMAIN FOR VERTICAL PIPE.
    • rajendrapor
      I wish to create an axi-symmetric model for a vertical pipe. How can I make the body to rotate about Y- axis. I saw in many posts that, axis of symmetry is x-axis for fluent and cannot be changed.
      You don't move the geometry, you move the world: gravity also has a vector.
    • rajendrapor
      Thanks! I figured out about the setting of fluent, after getting divergence. Just changed the vector_g to +x direction. Physics remains the same.
      Actually many threads are there where people wrote about getting divergence in axi-symmetric models. This is one of the primary reasons.
      It is, the secondary reason is having mesh in the y<0 position. Just remember that gravity ****, so if "up" is positive x the gravity vector is -9.81 Getting that one wrong is another very common mistake.
    • rajendrapor
      Thanks again! Very right. Hope this thread may help someone getting some errors due to these reasons.
Viewing 4 reply threads
  • The topic ‘AXI-SYMMETRIC DOMAIN FOR VERTICAL PIPE.’ is closed to new replies.
