April 28, 2025 at 1:06 pm
harley.b.long.civ
SubscriberI'm having issues using the bolt tool with a slot and thru hole. The tool doesn't work if I have it set to coaxial. If I set as non-coaxial it makes multiple bolts and does not regonize the length of the bolt. If this was mechanical I could select the slot walls and it would regonize it as a slot. With the assign bolt in discovery, it does not let me select the walls of the slot and only the rounds. Can someone help me on how to assign a bolt thru an not coaxial slot?Â
April 28, 2025 at 2:18 pm
Devendra Badgujar
Forum ModeratorHello,Â
Let me check this and get back to you.Â
DevendraÂ
Ansys Innovation Space
- Unable to attach geometry 2024 R2
- Data Center Simulation
- [SpaceClaim] STEP file size using Converter.exe
- How to do the snap fit insertion FEA?
- Spaceclaim 2024 error FNE activation failed
- PMI Product manufacturing information in SpaceClaim/Discovery modeling
- PlugIn Error: Failed to import assembly from SpaceClaim. The object is deleted.
970
857
761
599
