February 8, 2025 at 8:19 am
February 11, 2025 at 1:53 pm
Ram Gopisetti
Ansys EmployeeHi,Â
Please navigate to the solver file directory where all your results are stored ( this should be where your model is saved).Â
Then check all the .mes files and d3hsp files for errors.
This will give you an idea of what error is occurring then for further help please post that error for additional suggestions.Â
Cheers, RamÂ
February 11, 2025 at 2:21 pm
February 11, 2025 at 3:27 pm
Chris Quan
Ansys EmployeeWas the End Time 1E-5 sec? Is this time realistic? If not, can you use a more realistic and physically meaningful time and then re-run the model?
If the End Time is realisitic, what is the velocity resulted from the Displacement BC? If the velocity is very high, make sure material model can take care of the nonlinear physics involved, for example, plasticity, strain rate effect, material failure or damage, pressure hardening, etc.Â
Was Erosion on? Will the model run further if you reduce the number of cores from 16 to 4?
February 12, 2025 at 10:52 am
ihsanullah.khan
SubscriberThank you for your response, and I appreciate your help. I apologize if I am not providing the information correctly, as I am still new to ANSYS.
I have been trying to locate the .mes and d3hsp files, but I could not find them. I have attached a screenshot of my solver file directory for reference.
To explain further, I successfully obtained results for the hand-sutured sample, and I applied the same procedure to the stapler-sutured sample. However, I am facing issues with the stapler-sutured case.
I am using an Intel Core i7 laptop with 32GB RAM (10 physical cores and 16 logical threads), and that’s why I have set ANSYS to use 10 cores for the simulation.
I have been working on this issue for the past six months, trying different modifications such as adjusting the time step, refining the mesh, and tweaking other solver settings, but I have still not been able to get the correct results.
I would really appreciate your guidance in resolving this issue. I am also uploading all relevant screenshots as proof.
February 12, 2025 at 11:09 am
February 12, 2025 at 12:55 pm
Ram Gopisetti
Ansys EmployeeHi,Â
I was under the impression this is under LS-DYNA WB, It makes sense given this is Explicit dynamics.Â
Given that there is an energy error too large, try setting the Maximum energy error to a large number instead of 0.1
Have a read at link https://innovationspace.ansys.com/knowledge/forums/topic/how-to-deal-with-problem-terminated-energy-error-too-large/ , and follow these comments by my colleague. Â
"Was the End Time 1E-5 sec? Is this time realistic? If not, can you use a more realistic and physically meaningful time and then re-run the model?
Was Erosion on? Will the model run further if you reduce the number of cores from 16 to 4?"Â
Cheers, RamÂ
February 12, 2025 at 1:43 pm
ihsanullah.khan
SubscriberDear Ram,
Thank you for your response and guidance. I have implemented all the suggested steps as follows:
- Reduced the end time step to 1e-2 (further increase would make the simulation take over two days to complete).
- Increased Maximum Energy Error to 10 to allow more flexibility in the solver.
- Kept erosion enabled, as seen in the attached screenshot.
However, despite these changes, the simulation now stops at 1.5% progress without generating results or displaying any error messages, as shown in the attached screenshot.
I would appreciate your further insights on h
ow to resolve this issue. Thank you again for your support.
February 12, 2025 at 1:44 pm
- Unable to attach geometry 2024 R2
- Data Center Simulation
- DXF file loaded incorrectly
- Inventor 2025 files
- Ansys SpaceClaim and Discovery 2024 Facet shelling bug – 2022 version is better
- Masonry Brick Simulation
- Spaceclaim 2024 error FNE activation failed
- Simulating PCB
- How to do the snap fit insertion FEA?
1992
897
599
591
418
