Ansys Products
Ansys Products
Ansys Mechanical Reservable?
    • jared.clark
      Is the Ansys Mechanical ("ansys") license able to be reserved? If so, how can I do this? When I opent the client licensing settings and select "Borrow", it says "No Borrowable Licenses available".
    • Rajeshwari Jadhav
      Hi Jared,
      May I know which type of license do you have? If you want to borrow any license, the license file should have borrowable feature enabled.
      Please refer:
      https://youtu.be/7idHWwDVHrc?si=q6Paw4wuNI7Zd7V-
      1.2. Using the Ansys Licensing Settings Utility
