June 1, 2023 at 8:09 amAnish Mathew SajeevSubscriber
I am not able to use mechanical modeller as it shows license not found. The license server is configured correctly. I do not see lmutil running and couldnt install manually either.
June 1, 2023 at 9:03 pmVJAnsys Employee
Hi Anish,
What error are you seeing when you run lmutil? Launch Ansys Client Licensing Settings > FlexNet Publisher License Status.. do you see list of features or error code?
June 2, 2023 at 9:24 am
June 2, 2023 at 10:42 amVJAnsys Employee
What geometry format are you trying to attach?
June 2, 2023 at 10:51 amAnish Mathew SajeevSubscriber
I am importing parasolid file which was in the tutorial
Viewing 4 reply threads
- The topic ‘Ansys Mechanical 2022 R2 License Issue’ is closed to new replies.
Ansys Innovation Space
- Workbench license error
- Unexpected error on Workbench: Root element not found.
- Unexpected issues with SCCM deployment of Ansys Fluids and Structures 2024 R1
- Questions and recommendations: Septum Horn Antenna
- AQWA: Hydrodynamic response error
- Tutorial or Help for 2 way FSI
- Unable to connect to the license
- Moment Reaction probe with Large deformation
- 2 way coupled FSI for ball bearing
- Ansys with Vmware and CPU configuration : I’m lost, good practice?
599
591
565
366
