January 10, 2025 at 12:47 pm
nokdu19
SubscriberHello, I'm using the student version of Ansys, and as soon as I open the program, a warning window pops up with this message.
Ansys License Manager error
No such feature exists.
Feature: ansys:1, preppost:1, emag:1
License path:
C:\Users\dumbg\AppData\Local\Temp\\2669dff7-a48e-4e71-87e6-b7549aaad0a9c;
FiexNet Licensing error:-5,357Â Can anyone help me to resolve this error?
January 13, 2025 at 11:11 am
Rajeshwari Jadhav
Forum ModeratorHi,
Earlier did you use commerical/academic package if yes then please open your licensing settings from start menu, the license server should be off, disable it and save it.
Also goto "C:\Program Files\ANSYS Inc\Shared Files\Licensing" and remove the ansyslmd.ini file if it exists.
Rename the Ansys folder to Ansys.old (%appdata%) and .ansys folder to .ansys.old (%temp%)-
January 13, 2025 at 1:26 pm
nokdu19
SubscriberIt's still not working and another Ansys file appeared.
January 13, 2025 at 1:28 pm
Rajeshwari Jadhav
Forum ModeratorWhich package you used?
January 13, 2025 at 2:10 pm
nokdu19
SubscriberAnsys student 2024 R2
January 13, 2025 at 2:36 pm
Rajeshwari Jadhav
Forum ModeratorDid you delete ansyslmd.ini file?
January 13, 2025 at 2:49 pm
nokdu19
SubscriberÂ
There is no ansyslmd.ini file in the licensing folder.
I found it and I am deleting it now...Â
January 13, 2025 at 4:10 pm
nokdu19
SubscriberI can not find it at all after reinstalling it and the same problem happened again even after deleting it. There's probably an ansyslmd.ini file in the ansys folder.Â
January 16, 2025 at 11:56 am
e.g.
SubscriberI'm facing the same problem. Did you find any solution?
(I get the error -5,357 each time I try to run a calculation and I can't find any ansysmld.ini file).
5639
1885
1403
1303
