3D Design
3D Design
ANSYS Forte, starting Arrhenius settings for gasoline and diesel combustion PFI
    • Hasan
      I have a student version download and looking to start  modelling the above subject combustion chemistry. I think the only way to start this is to use the Forte materials library, then enter Arrhenius parameters for the two fuels to combustion together.
      Q1: where can I enter or select Arrhenius reaction model.
      Q2: where can in find parameters inputs for gasoline and diesel Arrhenius inputs?
    • Ren
      In Forte, the reaction data are not manually entered by the user. Instead, the reaction data are stored in a mechanism file and preprocessed as a Chemkin chemistry set file and then imported into Forte. Please refer to the user guide chapter 3.3.1 Chemistry/Materials for details. I'd also recommend that you work through some standard tutorials on modelling gasoline or diesel engines to learn the procedures.
    • Hasan
      I have looked at Forte tutorial diesel/ gasoline using sector nesh but with a student software it doesn't work. Now tried selection of diesel and gasoline from the fuel_library.cks file and running tutorial 5 PFI tutorial. Diesel 10% & gasoline 90% with all selections as per tutorial, I think it will crash when ignition CA is reached. Mostly I need to change something in the Flame Speed Model tab.
      Thanks.
    • Hasan
      Ren thanks but is there a way in making tutorial chapter 3 duel fuel sector mesh work for academic work? The message I got is that this tutorial can not run on Forte student version.
