January 7, 2025 at 4:55 pm
rameyers
SubscriberWe have been able to consistently cause our virtual environment to crash in Ansys Discovery when using a specific sldprt file and physics. The problem could be triggered by other GPU heavy software but "insert geometry" in Ansys Discovery seems to be the most reliable. We've been working with Nvidia for over a year and they've been iterating fixes into the vGPU drivers but we're still having problems. Has anyone had any similar issues or able to provide insight or guidance?
Below are the specific steps I am able to use to cause it to crash most consistently.
Launch Ansys Discovery 2024 R2
Insert geometry: P2_Bracket_V4.SLDPRT
Align in V shape with shorter/thinner end on the right side
Set the Material to "User Defined Solid" and update the properties
Density: 1.18e3 kg/m3
Electrical conductivity: 0
Relative permittivity: 1
Electrical loss tangent: 0
Relative permeability: 1
Young's modulus: 3.1e9 Pa
Poisson's ratio: .37
Shear modulus: 1.13e9 Pa (should be set automatically)
Bulk modulus: 3.97e9 Pa (should be set automatically)
Tensile yield strength: 7.03e7 Pa
Tensile ultimate strength: 1.03e8 Pa
Thermal expansion coefficient: 5e-5 1/C
Thermal conductivity: .19 W/m-K
Specific heat: 5e-5 kJ/kg.C
Material: Acrylic (PMMA)
Set upper left circular hole structure as Fixed Support
Set upper right circular hole structure as Displaced Support
dx: 0m
dy: free
dz: 0m
0x: 0
0y: 0
0z: 040Â
Displacement: 0m
Rotation: 0
Click into dx and hit Enter to save it
Set the bottom circular hole structure as Distributed Force
Force: 80 lbf
Force direction: Down
Set the arch (see image below for specific location) as Distributed Force
Solve model
If the app crashes, but the VM doesn’t, repeat the above steps.
I saved Design with P4.dsco file with all of the above configuration steps that should work in place of steps 2-8.
Hardware:
Servers: Dell R7525
CPUs: AMD EPYC 75F3 (2x per server)
GPUs: Nvidia L40 (2x per server)
Software:
ESXi: 8.0 U3b build 24280767 (problem has persisted on various versions of ESXi 7 and 8)
Nvidia vGPU: 16.8 (and all previous versions of 16.x)
vGPU Profile: L40-8Q (up to 6 per card, 12 per server)
Ansys Discovery 2024 R2 Build 20240531
January 10, 2025 at 6:07 am
Atharv Joshi
Forum ModeratorHi Rameyers,ÂÂThanks for sharing the details about your problem.ÂWe are not allowed to access the models as this public forum. If needed, I will reach out to for files through secure transfer.ÂLet me check this and I will get back to you.ÂÂRegardsAtharvÂ
- Unable to attach geometry 2024 R2
- Data Center Simulation
- [SpaceClaim] STEP file size using Converter.exe
- How to do the snap fit insertion FEA?
- Spaceclaim 2024 error FNE activation failed
- PMI Product manufacturing information in SpaceClaim/Discovery modeling
- PlugIn Error: Failed to import assembly from SpaceClaim. The object is deleted.
2979
970
857
750
599
