3D Design
3D Design
Ansys Discovery
    • Roberto
      Hello
      Is it possible to improve the ability to customize simulation reports? This is important for those who run simulations.
      It would be nice to be able to completely customize the default report with the values ​​you want to see and the scenes created.
      Regards
    • Devendra Badgujar
      Hello Roberto,
      Thanks for your feedback. As of now, you cannot edit it from Discovery, but when you create a word doc for the report you have option to edit what you want.
      I will forward your suggestion to have customize ability.
      Devendra
    • Roberto
      Hello Devendra
      Thank you for requesting it as an improvement, usually those who do simulation need to be able to create a report and it would be good to be able to customize it with the data you want and also the format
      I also noticed another thing that doesn't seem to be working properly.
      When I have a file with several scenes and several simulations like the first image in the attachment, when I save the report with all the scenes it doesn't include them, it inserts them at home sometimes one yes and one no or none or all of them for each simulation.
      It would be nice if you could save this graph in image format ( png , jpg)
      I saw that it is possible to exclude parts from the simulation, I would like to ask if it is possible to exclude from the simulation parts, but keeping only the constraints
