November 11, 2024 at 3:23 am
hewetti
SubscriberHello,Â
While following this 3 point bend tutorial (16:22), I got the following error when using ACP post. Below is a screenshot of the error, and a paste of the log file. Any insight would be appreaciated.Â
2024-11-10 19:07:21.401934 info: Runtime arguments:
2024-11-10 19:07:21.401934 info: - Command line options: {'batch_mode': 0, 'debug': False, 'num_threads': None, 'logfile': None, 'mode': 'post', 'workbench': True, 'port': 55206}
2024-11-10 19:07:21.408985 info: - Script file: \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\ACP-Post\ACP\runACP.py
2024-11-10 19:07:45.368325 info: WorkbenchConnection connected to port 55206.
2024-11-10 19:07:45.369350 info: Sending notification hello
2024-11-10 19:07:45.369350 info:Â - Serialized Request: {"jsonrpc": "2.0", "method": "hello"}
2024-11-10 19:07:45.508479 info: Initialize Ansys ACLE license manager for acp: Successful
2024-11-10 19:07:45.825813 info: Checkout of ACP product license with Ansys ACLE license manager: Checkout successful (server= 1055@linlic8.engr.oregonstate.edu, client=xd-ms01-18_engineering_oregonstate_edu-username-5268-001845).
2024-11-10 19:07:45.875942 info: Execute Script: \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\ACP-Post\ACP\runACP.py
2024-11-10 19:07:45.925157 info: Finished execution of \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\ACP-Post\ACP\runACP.py after t= 0.05s
2024-11-10 19:07:45.942701 info: Received Request: method=update_system_coordinates, params=['C:ACP (Post)'], id=1
2024-11-10 19:07:46.013782 info: Sending Response: success, result=None, id=1
2024-11-10 19:07:46.013782 info: Received Request: method=wbrefresh, params=[True, '\\\\users\\username\\Windows.Documents\\Desktop\\ATT2Y_AXIS\\LEAP AUS\\LEAP-AUS-TEST_files\\dp0\\ACP-Post\\ACP\\ACP-Post.acph5', '{\'pre_db\' : {\'external_id\':u"Setup", \'path\':u"\\\\\\\\\\users\\\\username\\\\Windows.Documents\\\\Desktop\\\\ATT2Y_AXIS\\\\LEAP AUS\\\\LEAP-AUS-TEST_files\\\\dp0\\\\ACP-Pre\\\\ACP\\\\ACP-Pre.acph5", \'modified\':True, }, \'solutions\' : [{\'external_id\':u"Solution", \'modified\':True, \'path\':u"", \'name\':u"Solution 1", }, ], }', '', ''], id=2
2024-11-10 19:07:46.024816 info: refresh acph5: path='\\\\users\\username\\Windows.Documents\\Desktop\\ATT2Y_AXIS\\LEAP AUS\\LEAP-AUS-TEST_files\\dp0\\ACP-Post\\ACP\\ACP-Post.acph5', external_sources={'pre_db': {'external_id': 'Setup', 'path': '\\\\users\\username\\Windows.Documents\\Desktop\\ATT2Y_AXIS\\LEAP AUS\\LEAP-AUS-TEST_files\\dp0\\ACP-Pre\\ACP\\ACP-Pre.acph5', 'modified': True}, 'solutions': [{'external_id': 'Solution', 'modified': True, 'path': '', 'name': 'Solution 1'}]}, input_parameters=None, initialize=True, unit_system_type=None, upgrade_from=None
2024-11-10 19:07:46.024816 info: Create empty acph5 \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\ACP-Post\ACP\ACP-Post.acph5
2024-11-10 19:07:46.095350 info: Refresh acph5 \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\ACP-Post\ACP\ACP-Post.acph5 with \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\ACP-Pre\ACP\ACP-Pre.acph5
2024-11-10 19:07:46.395693 info: Open database from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\ACP-Post\ACP\ACP-Post.acph5
2024-11-10 19:07:46.397694 info: Importing acp:h5 model from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\ACP-Post\ACP\ACP-Post.acph5
2024-11-10 19:07:46.397694 info: Load ACP model from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\ACP-Post\ACP\ACP-Post.acph5
2024-11-10 19:07:46.410798 info: - File version: 24.2
2024-11-10 19:07:46.425009 info: - Defining data:
2024-11-10 19:07:46.425009 info: Data set ACP/ExternalData/InputFile / Data not found in "\users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\ACP-Post\ACP\ACP-Post.acph5"!
2024-11-10 19:07:46.475684 info: - Load cached data
2024-11-10 19:07:46.591630 info: - Ignoring data for ElemWisePlyProperty.node_thicknesses because number of objects (11340) and number of property values ( 0) do not match.
2024-11-10 19:07:46.591630 info: - Ignoring data for ElemWisePlyProperty.fabric_fiber_angle because number of objects (11340) and number of property values ( 0) do not match.
2024-11-10 19:07:46.591630 info: Finished loading of ACP model after 0.203 seconds
2024-11-10 19:07:46.591630 info: Finished post-load upgrade after 0.203 seconds
2024-11-10 19:07:46.662178 info: Load materials from Engineering Data file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\ACP-Post\ACP\f359c201-6c33-4596-a7db-ee9350e1c76f.matml.engd
2024-11-10 19:07:46.682265 info: End of material load from Engineering Data file.
2024-11-10 19:07:46.732242 info: Send unit system change to WB: UnitSystem( type=mpa )
2024-11-10 19:07:46.732242 info: Sending notification status
2024-11-10 19:07:46.732242 info:Â - Serialized Request: {"jsonrpc": "2.0", "method": "status", "params": ["unit_system_changed", "mpa"]}
2024-11-10 19:07:46.977134 info: Check model consistency
2024-11-10 19:07:46.977290 info: Set Unit System: from UnitSystem( type=mpa ) to mpa
2024-11-10 19:07:46.977290 info:Â - Unit System is equal to unit system already assigned to the Model.
2024-11-10 19:07:47.541516 info: Sending notification status
2024-11-10 19:07:47.541516 info:Â - Serialized Request: {"jsonrpc": "2.0", "method": "status", "params": ["modified"]}
2024-11-10 19:07:47.545054 info: Sending Response: success, result=(True, '\\\\users\\username\\Windows.Documents\\Desktop\\ATT2Y_AXIS\\LEAP AUS\\LEAP-AUS-TEST_files\\dp0\\ACP-Post\\ACP\\ACP-Post.acph5'), id=2
2024-11-10 19:07:47.713044 info: Received Request: method=focus, params={}, id=None
2024-11-10 19:08:08.763937 info: Update object(s): CombinedFailureCriteria('FailureCriteria.1') ...
2024-11-10 19:08:08.820059 info: Update solid model SolidModel.1
2024-11-10 19:08:08.820059 info: Update of solid model SolidModel.1 finished. t=0.000 seconds
2024-11-10 19:08:08.823060 info: Update of plot object Thickness.1 finished after 0.003 seconds
2024-11-10 19:08:20.313254 info: Update object(s): CombinedFailureCriteria('FailureCriteria.1') ...
2024-11-10 19:08:20.360100 info: Update solid model SolidModel.1
2024-11-10 19:08:20.360100 info: Update of solid model SolidModel.1 finished. t=0.000 seconds
2024-11-10 19:08:20.360100 info: Update of plot object Thickness.1 finished after 0.000 seconds
2024-11-10 19:08:53.411645 info: Update object(s): FailureData('Failure.1') ...
2024-11-10 19:08:54.208689 info: Update solid model SolidModel.1
2024-11-10 19:08:54.208689 info: Update of solid model SolidModel.1 finished. t=0.000 seconds
2024-11-10 19:08:54.208689 info: Update of plot object Thickness.1 finished after 0.000 seconds
2024-11-10 19:08:54.303125 error: File path () of solution Solution 1 does not exist! Please assign new path or delete.
2024-11-10 19:09:26.812431 info: Received Request: method=wbrefresh, params=[False, '\\\\users\\username\\Windows.Documents\\Desktop\\ATT2Y_AXIS\\LEAP AUS\\LEAP-AUS-TEST_files\\dp0\\ACP-Post\\ACP\\ACP-Post.acph5', '{\'pre_db\' : {\'external_id\':u"Setup", \'path\':u"\\\\\\\\\\users\\\\username\\\\Windows.Documents\\\\Desktop\\\\ATT2Y_AXIS\\\\LEAP AUS\\\\LEAP-AUS-TEST_files\\\\dp0\\\\ACP-Pre\\\\ACP\\\\ACP-Pre.acph5", \'modified\':False, }, \'solutions\' : [{\'external_id\':u"Solution", \'modified\':True, \'path\':u"\\\\\\\\\\users\\\\username\\\\Windows.Documents\\\\Desktop\\\\ATT2Y_AXIS\\\\LEAP AUS\\\\LEAP-AUS-TEST_files\\\\dp0\\\\SYS\\\\MECH\\\\file.rst", \'name\':u"Solution 1", \'renumbering_mapping_paths\':[u"\\\\\\\\\\users\\\\username\\\\Windows.Documents\\\\Desktop\\\\ATT2Y_AXIS\\\\LEAP AUS\\\\LEAP-AUS-TEST_files\\\\dp0\\\\SYS\\\\MECH\\\\Setup\\\\ACPSolidModel_SolidModel.1.mapping"], }, ], }', '', ''], id=3
2024-11-10 19:09:26.812431 info: refresh acph5: path='\\\\users\\username\\Windows.Documents\\Desktop\\ATT2Y_AXIS\\LEAP AUS\\LEAP-AUS-TEST_files\\dp0\\ACP-Post\\ACP\\ACP-Post.acph5', external_sources={'pre_db': {'external_id': 'Setup', 'path': '\\\\users\\username\\Windows.Documents\\Desktop\\ATT2Y_AXIS\\LEAP AUS\\LEAP-AUS-TEST_files\\dp0\\ACP-Pre\\ACP\\ACP-Pre.acph5', 'modified': False}, 'solutions': [{'external_id': 'Solution', 'modified': True, 'path': '\\\\users\\username\\Windows.Documents\\Desktop\\ATT2Y_AXIS\\LEAP AUS\\LEAP-AUS-TEST_files\\dp0\\SYS\\MECH\\file.rst', 'name': 'Solution 1', 'renumbering_mapping_paths': ['\\\\users\\username\\Windows.Documents\\Desktop\\ATT2Y_AXIS\\LEAP AUS\\LEAP-AUS-TEST_files\\dp0\\SYS\\MECH\\Setup\\ACPSolidModel_SolidModel.1.mapping']}]}, input_parameters=None, initialize=False, unit_system_type=None, upgrade_from=None
2024-11-10 19:09:27.258650 info: Sending Response: success, result=(False, '\\\\users\\username\\Windows.Documents\\Desktop\\ATT2Y_AXIS\\LEAP AUS\\LEAP-AUS-TEST_files\\dp0\\ACP-Post\\ACP\\ACP-Post.acph5'), id=3
2024-11-10 19:09:27.258650 info: Received Request: method=wbupdate, params={}, id=4
2024-11-10 19:09:27.285376 info: Update object(s): Model(name='ACP Model', path='//depot.engr.oregonstate.edu/users/username/Windows.Documents/Desktop/ATT2Y_AXIS/LEAP AUS/LEAP-AUS-TEST_files/dp0/ACP-Post/ACP/../MECH/ACP-Pre.h5', format='ansys:h5') ...
2024-11-10 19:09:27.326047 info: Update solid model SolidModel.1
2024-11-10 19:09:27.326047 info: Update of solid model SolidModel.1 finished. t=0.000 seconds
2024-11-10 19:09:27.326047 info: Update of plot object Thickness.1 finished after 0.000 seconds
2024-11-10 19:09:27.326047 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:09:27.345081 info: - File size: 44.125 MB
2024-11-10 19:09:27.345081 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:09:27.355092 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:09:27.375433 info: - Analysis type: 0
2024-11-10 19:09:27.375433 info: - Number of data sets: 9
2024-11-10 19:09:27.379467 info: Load Ansys results from RST file
2024-11-10 19:09:27.379467 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:09:27.392110 info: - File size: 44.125 MB
2024-11-10 19:09:27.392110 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:09:27.392110 info: Parsing Ansys RST file: \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:09:27.412618 info: - Parse RST file headers
2024-11-10 19:09:27.412618 info: - RST file does not contain principal stress data
2024-11-10 19:09:27.412618 info: - Reading data set 9 of 9.
2024-11-10 19:09:27.442713 info: - Parse nodal deformations
2024-11-10 19:09:27.452719 info:Â Â # nodal result sets read : 19688
2024-11-10 19:09:27.452719 info: - Parse stresses and strains
2024-11-10 19:09:27.452719 info:Â Â - Load strain and stress data: true
2024-11-10 19:09:27.452719 info: - Parse results of 8984 elements
2024-11-10 19:09:27.513518 info:Â Â # element shear forces read : 0
2024-11-10 19:09:27.513518 info:Â Â # element stress result sets read : 6935
2024-11-10 19:09:27.513518 info:Â Â # element strain result sets read : 6935
2024-11-10 19:09:27.513518 info:Â Â # element nodal temperature result sets read : 8413
2024-11-10 19:09:27.513518 info:Â Â # material non-linear sets read : 0
2024-11-10 19:09:27.513518 info:Â Â Parsing of element results finished after 0.059 seconds
2024-11-10 19:09:27.523594 info: Applying assembly renumbering to solution containers...
2024-11-10 19:09:27.525098 info: Load mesh mapping from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\Setup\ACPSolidModel_SolidModel.1.mapping
2024-11-10 19:09:27.553723 info:Â Â - Realocate element results ...
2024-11-10 19:09:27.568995 info:Â Â - Realocate nodal results ...
2024-11-10 19:09:27.572995 info: - Process nodal results ...
2024-11-10 19:09:27.575563 info:Â Â Processed 7040 nodes. t=0.002 seconds
2024-11-10 19:09:27.575563 info:Â Â WARNING: Nodal results for 704 nodes are MISSING and are set to 0.0.
2024-11-10 19:09:27.575563 info: - Process nodal rotations (from nodal to global csys) ...
2024-11-10 19:09:27.575563 info:Â Â Processed 0 rotations. t=0.001 seconds
2024-11-10 19:09:27.575563 info: - Process progressive damage results:
2024-11-10 19:09:27.575563 info:Â Â No progressive damage data available
2024-11-10 19:09:27.575563 info: - Process element strain and stress results ...
2024-11-10 19:09:27.585070 info:Â Â Done for 5670 elements. t=0.011 seconds
2024-11-10 19:09:27.585070 info: - Process shear forces ...
2024-11-10 19:09:27.585070 info:Â Â Â Â Done
2024-11-10 19:09:27.585070 info: Convert loaded results from RST file unit system UnitSystem( length=mm, mass=t, time=s, force=N, temperature=C, currency=USD) to model unit system UnitSystem( length=mm, mass=t, time=s, force=N, temperature=C, currency=USD)
2024-11-10 19:09:27.592076 info: Start ACP post-processing computation.
2024-11-10 19:09:27.592076 info: - Evaluation/update of the following quantities has been requested:
2024-11-10 19:09:27.592076 info:Â Â Strains
2024-11-10 19:09:27.592076 info:Â Â In-plane stresses s1, s2, s12
2024-11-10 19:09:27.592076 info:Â Â Interlaminar shear stresses s13 and s23
2024-11-10 19:09:27.592076 info:Â Â Maximum strain failure criteria
2024-11-10 19:09:27.592076 info:Â Â Maximum stress failure criteria
2024-11-10 19:09:27.592076 info:Â Â 2D Tsai-Wu failure criteria
2024-11-10 19:09:27.592076 info:Â Â 2D Tsai-Hill failure criteria
2024-11-10 19:09:27.592076 info:Â Â 2D Hashin failure criteria
2024-11-10 19:09:27.592076 info:Â Â 2D Puck failure criteria
2024-11-10 19:09:27.592076 info:Â Â 2D Cuntze failure criteria
2024-11-10 19:09:27.592076 info:Â Â Sandwich core shear criteria
2024-11-10 19:09:27.592076 info:Â Â Â Active layered elements: 5670
2024-11-10 19:09:27.592076 info:Â Â Â Active solver elements: 0
2024-11-10 19:09:27.592076 info: - Start computation (5670 element(s) selected)...
2024-11-10 19:09:27.595082 info:Â Â Â Â 10% finished (568 of 5670)
2024-11-10 19:09:27.595082 info:Â Â Â Â 20% finished (1136 of 5670)
2024-11-10 19:09:27.595082 info:Â Â Â Â 30% finished (1704 of 5670)
2024-11-10 19:09:27.605092 info:Â Â Â Â 40% finished (2272 of 5670)
2024-11-10 19:09:27.608598 info:Â Â Â Â 50% finished (2840 of 5670)
2024-11-10 19:09:27.608598 info:Â Â Â Â 60% finished (3408 of 5670)
2024-11-10 19:09:27.615107 info:Â Â Â Â 70% finished (3976 of 5670)
2024-11-10 19:09:27.615107 info:Â Â Â Â 80% finished (4536 of 5670)
2024-11-10 19:09:27.615107 info:Â Â Â Â 90% finished (5104 of 5670)
2024-11-10 19:09:27.615107 info:Â Â Â Â 100% finished (5670 of 5670)
2024-11-10 19:09:27.625184 info:Â Â done for 5670 elements.
2024-11-10 19:09:28.408882 error: Failure criteria evaluation failed: NaN values detected. This is an internal logic error, please report this to the ACP developers.
2024-11-10 19:09:28.563963 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:09:28.575156 info: - File size: 44.125 MB
2024-11-10 19:09:28.575156 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:09:28.575156 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:09:28.595082 info: - Analysis type: 0
2024-11-10 19:09:28.595082 info: - Number of data sets: 9
2024-11-10 19:09:28.658496 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:09:28.670056 info: - File size: 44.125 MB
2024-11-10 19:09:28.670056 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:09:28.675162 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:09:28.685189 info: - Analysis type: 0
2024-11-10 19:09:28.685189 info: - Number of data sets: 9
2024-11-10 19:09:28.695254 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:09:28.708336 info: - File size: 44.125 MB
2024-11-10 19:09:28.708336 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:09:28.708336 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:09:28.715344 info: - Analysis type: 0
2024-11-10 19:09:28.715344 info: - Number of data sets: 9
2024-11-10 19:09:28.725927 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:09:28.741993 info: - File size: 44.125 MB
2024-11-10 19:09:28.741993 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:09:28.741993 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:09:28.745596 info: - Analysis type: 0
2024-11-10 19:09:28.745596 info: - Number of data sets: 9
2024-11-10 19:09:28.832290 error: The ACP update did not succeed. Please see the log for more details.
2024-11-10 19:09:28.841797 info: Sending JSONRPCErrorResponse(jsonrpc='2.0',id=4,error={'message': 'Traceback (most recent call last):\n File "C:\\ANSYSDev\\tfs_agent\\_work\\645\\s\\dependencies\\ThirdParty\\CPython\\3_10\\winx64\\Release\\python\\lib\\code.py", line 90, in runcode\n File "", line 1, in
\n File "c:\\ansysdev\\tfs_agent\\_work\\645\\s\\felyx\\python\\compolyx\\model.py", line 2217, in wbupdate\nRuntimeError: The ACP update did not succeed. Please see the log for more details.\n', 'code': -32000}) 2024-11-10 19:10:06.008486 info: Received Request: method=focus, params={}, id=None
2024-11-10 19:10:14.058502 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:14.075167 info: - File size: 44.125 MB
2024-11-10 19:10:14.075167 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:10:14.075167 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:14.084206 info: - Analysis type: 0
2024-11-10 19:10:14.084206 info: - Number of data sets: 9
2024-11-10 19:10:16.443622 info: Update object(s): FailureData('Failure.1') ...
2024-11-10 19:10:16.732409 info: Update solid model SolidModel.1
2024-11-10 19:10:16.732409 info: Update of solid model SolidModel.1 finished. t=0.000 seconds
2024-11-10 19:10:16.733416 info: Update of plot object Thickness.1 finished after 0.000 seconds
2024-11-10 19:10:16.735416 info: Start ACP post-processing computation.
2024-11-10 19:10:16.735416 info: - Evaluation/update of the following quantities has been requested:
2024-11-10 19:10:16.735416 info:Â Â Strains
2024-11-10 19:10:16.735416 info:Â Â In-plane stresses s1, s2, s12
2024-11-10 19:10:16.735416 info:Â Â Interlaminar shear stresses s13 and s23
2024-11-10 19:10:16.735416 info:Â Â Maximum strain failure criteria
2024-11-10 19:10:16.735416 info:Â Â Maximum stress failure criteria
2024-11-10 19:10:16.735416 info:Â Â 2D Tsai-Wu failure criteria
2024-11-10 19:10:16.735416 info:Â Â 2D Tsai-Hill failure criteria
2024-11-10 19:10:16.735416 info:Â Â 2D Hashin failure criteria
2024-11-10 19:10:16.735416 info:Â Â 2D Puck failure criteria
2024-11-10 19:10:16.735416 info:Â Â 2D Cuntze failure criteria
2024-11-10 19:10:16.735416 info:Â Â Sandwich core shear criteria
2024-11-10 19:10:16.738419 info:Â Â Â Active layered elements: 5670
2024-11-10 19:10:16.738419 info:Â Â Â Active solver elements: 0
2024-11-10 19:10:16.738419 info: - Start computation (5670 element(s) selected)...
2024-11-10 19:10:16.740426 info:Â Â Â Â 10% finished (568 of 5670)
2024-11-10 19:10:16.742066 info:Â Â Â Â 20% finished (1136 of 5670)
2024-11-10 19:10:16.742066 info:Â Â Â Â 30% finished (1704 of 5670)
2024-11-10 19:10:16.742066 info:Â Â Â Â 40% finished (2272 of 5670)
2024-11-10 19:10:16.742066 info:Â Â Â Â 50% finished (2840 of 5670)
2024-11-10 19:10:16.752068 info:Â Â Â Â 60% finished (3408 of 5670)
2024-11-10 19:10:16.752068 info:Â Â Â Â 70% finished (3976 of 5670)
2024-11-10 19:10:16.758581 info:Â Â Â Â 80% finished (4536 of 5670)
2024-11-10 19:10:16.758581 info:Â Â Â Â 90% finished (5104 of 5670)
2024-11-10 19:10:16.762675 info:Â Â Â Â 100% finished (5670 of 5670)
2024-11-10 19:10:16.762675 info:Â Â done for 5670 elements.
2024-11-10 19:10:16.831899 error: Failure criteria evaluation failed: NaN values detected. This is an internal logic error, please report this to the ACP developers.
2024-11-10 19:10:16.893505 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:16.904514 info: - File size: 44.125 MB
2024-11-10 19:10:16.905514 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:10:16.906522 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:16.917406 info: - Analysis type: 0
2024-11-10 19:10:16.917406 info: - Number of data sets: 9
2024-11-10 19:10:16.995483 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:17.005492 info: - File size: 44.125 MB
2024-11-10 19:10:17.005492 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:10:17.008499 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:17.015507 info: - Analysis type: 0
2024-11-10 19:10:17.015507 info: - Number of data sets: 9
2024-11-10 19:10:17.026082 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:17.042147 info: - File size: 44.125 MB
2024-11-10 19:10:17.045163 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:10:17.045163 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:17.055203 info: - Analysis type: 0
2024-11-10 19:10:17.055203 info: - Number of data sets: 9
2024-11-10 19:10:17.072636 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:17.084320 info: - File size: 44.125 MB
2024-11-10 19:10:17.084320 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:10:17.085349 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:17.092302 info: - Analysis type: 0
2024-11-10 19:10:17.092302 info: - Number of data sets: 9
2024-11-10 19:10:17.212976 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:17.225066 info: - File size: 44.125 MB
2024-11-10 19:10:17.225066 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:10:17.225066 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:17.232111 info: - Analysis type: 0
2024-11-10 19:10:17.232111 info: - Number of data sets: 9
2024-11-10 19:10:17.255688 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:17.266812 info: - File size: 44.125 MB
2024-11-10 19:10:17.268317 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:10:17.269378 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:17.276204 info: - Analysis type: 0
2024-11-10 19:10:17.276204 info: - Number of data sets: 9
2024-11-10 19:10:17.295793 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:17.305801 info: - File size: 44.125 MB
2024-11-10 19:10:17.308808 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:10:17.308808 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:17.315839 info: - Analysis type: 0
2024-11-10 19:10:17.315839 info: - Number of data sets: 9
2024-11-10 19:10:17.476092 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:17.482601 info: - File size: 44.125 MB
2024-11-10 19:10:17.482601 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:10:17.482601 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:17.492109 info: - Analysis type: 0
2024-11-10 19:10:17.492109 info: - Number of data sets: 9
2024-11-10 19:10:21.525492 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:21.537986 info: - File size: 44.125 MB
2024-11-10 19:10:21.538566 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:10:21.540244 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:21.547571 info: - Analysis type: 0
2024-11-10 19:10:21.547571 info: - Number of data sets: 9
2024-11-10 19:10:21.567656 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:21.578227 info: - File size: 44.125 MB
2024-11-10 19:10:21.578227 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:10:21.578227 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:21.591787 info: - Analysis type: 0
2024-11-10 19:10:21.591787 info: - Number of data sets: 9
2024-11-10 19:10:21.611483 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:21.622389 info: - File size: 44.125 MB
2024-11-10 19:10:21.623396 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:10:21.624381 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:10:21.637202 info: - Analysis type: 0
2024-11-10 19:10:21.637202 info: - Number of data sets: 9
2024-11-10 19:11:03.475098 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:11:03.485468 info: - File size: 44.125 MB
2024-11-10 19:11:03.485468 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:11:03.485468 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:11:03.495577 info: - Analysis type: 0
2024-11-10 19:11:03.495577 info: - Number of data sets: 9
2024-11-10 19:11:06.995820 info: Update object(s): FailureData('Failure.1') ...
2024-11-10 19:11:07.110241 info: Update solid model SolidModel.1
2024-11-10 19:11:07.110241 info: Update of solid model SolidModel.1 finished. t=0.000 seconds
2024-11-10 19:11:07.111251 info: Update of plot object Thickness.1 finished after 0.000 seconds
2024-11-10 19:11:07.113250 info: Start ACP post-processing computation.
2024-11-10 19:11:07.113250 info: - Evaluation/update of the following quantities has been requested:
2024-11-10 19:11:07.113250 info:Â Â Strains
2024-11-10 19:11:07.113250 info:Â Â In-plane stresses s1, s2, s12
2024-11-10 19:11:07.113250 info:Â Â Interlaminar shear stresses s13 and s23
2024-11-10 19:11:07.113250 info:Â Â Maximum strain failure criteria
2024-11-10 19:11:07.113250 info:Â Â Maximum stress failure criteria
2024-11-10 19:11:07.113250 info:Â Â 2D Tsai-Wu failure criteria
2024-11-10 19:11:07.113250 info:Â Â 2D Tsai-Hill failure criteria
2024-11-10 19:11:07.113250 info:Â Â 2D Hashin failure criteria
2024-11-10 19:11:07.113250 info:Â Â 2D Puck failure criteria
2024-11-10 19:11:07.113250 info:Â Â 2D Cuntze failure criteria
2024-11-10 19:11:07.113250 info:Â Â Sandwich core shear criteria
2024-11-10 19:11:07.116248 info:Â Â Â Active layered elements: 5670
2024-11-10 19:11:07.116248 info:Â Â Â Active solver elements: 0
2024-11-10 19:11:07.117247 info: - Start computation (5670 element(s) selected)...
2024-11-10 19:11:07.119247 info:Â Â Â Â 10% finished (568 of 5670)
2024-11-10 19:11:07.122248 info:Â Â Â Â 20% finished (1136 of 5670)
2024-11-10 19:11:07.124247 info:Â Â Â Â 30% finished (1704 of 5670)
2024-11-10 19:11:07.126434 info:Â Â Â Â 40% finished (2272 of 5670)
2024-11-10 19:11:07.129445 info:Â Â Â Â 50% finished (2840 of 5670)
2024-11-10 19:11:07.131445 info:Â Â Â Â 60% finished (3408 of 5670)
2024-11-10 19:11:07.134445 info:Â Â Â Â 70% finished (3976 of 5670)
2024-11-10 19:11:07.136446 info:Â Â Â Â 80% finished (4536 of 5670)
2024-11-10 19:11:07.139020 info:Â Â Â Â 90% finished (5104 of 5670)
2024-11-10 19:11:07.142020 info:Â Â Â Â 100% finished (5670 of 5670)
2024-11-10 19:11:07.142020 info:Â Â done for 5670 elements.
2024-11-10 19:11:07.212534 error: Failure criteria evaluation failed: NaN values detected. This is an internal logic error, please report this to the ACP developers.
2024-11-10 19:11:07.232619 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:11:07.252142 info: - File size: 44.125 MB
2024-11-10 19:11:07.252142 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:11:07.258663 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:11:07.262271 info: - Analysis type: 0
2024-11-10 19:11:07.262271 info: - Number of data sets: 9
2024-11-10 19:11:07.345649 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:11:07.365753 info: - File size: 44.125 MB
2024-11-10 19:11:07.365753 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:11:07.365753 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:11:07.378917 info: - Analysis type: 0
2024-11-10 19:11:07.378917 info: - Number of data sets: 9
2024-11-10 19:11:07.395520 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:11:07.405527 info: - File size: 44.125 MB
2024-11-10 19:11:07.405527 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:11:07.408614 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:11:07.415644 info: - Analysis type: 0
2024-11-10 19:11:07.415644 info: - Number of data sets: 9
2024-11-10 19:11:07.435227 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:11:07.445239 info: - File size: 44.125 MB
2024-11-10 19:11:07.445239 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:11:07.445239 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:11:07.460748 info: - Analysis type: 0
2024-11-10 19:11:07.460748 info: - Number of data sets: 9
2024-11-10 19:11:47.219792 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:11:47.227129 info: - File size: 44.125 MB
2024-11-10 19:11:47.227129 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:11:47.235673 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:11:47.245731 info: - Analysis type: 0
2024-11-10 19:11:47.245731 info: - Number of data sets: 9
2024-11-10 19:11:47.258784 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:11:47.275408 info: - File size: 44.125 MB
2024-11-10 19:11:47.275408 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:11:47.276414 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:11:47.285454 info: - Analysis type: 0
2024-11-10 19:11:47.285454 info: - Number of data sets: 9
2024-11-10 19:11:47.295499 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:11:47.315574 info: - File size: 44.125 MB
2024-11-10 19:11:47.315574 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:11:47.315574 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:11:47.326046 info: - Analysis type: 0
2024-11-10 19:11:47.326046 info: - Number of data sets: 9
2024-11-10 19:11:47.717760 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:11:47.731288 info: - File size: 44.125 MB
2024-11-10 19:11:47.731288 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:11:47.732219 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:11:47.742498 info: - Analysis type: 0
2024-11-10 19:11:47.742498 info: - Number of data sets: 9
2024-11-10 19:11:47.758683 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:11:47.762393 info: - File size: 44.125 MB
2024-11-10 19:11:47.772627 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:11:47.772627 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:11:47.782645 info: - Analysis type: 0
2024-11-10 19:11:47.782645 info: - Number of data sets: 9
2024-11-10 19:11:47.792155 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:11:47.812812 info: - File size: 44.125 MB
2024-11-10 19:11:47.812812 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:11:47.812812 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:11:47.825419 info: - Analysis type: 0
2024-11-10 19:11:47.825419 info: - Number of data sets: 9
2024-11-10 19:12:01.125330 info: Update object(s): FailureData('Failure.1') ...
2024-11-10 19:12:01.453258 info: Update solid model SolidModel.1
2024-11-10 19:12:01.453258 info: Update of solid model SolidModel.1 finished. t=0.000 seconds
2024-11-10 19:12:01.453258 info: Update of plot object Thickness.1 finished after 0.000 seconds
2024-11-10 19:12:01.458769 info: Start ACP post-processing computation.
2024-11-10 19:12:01.458769 info: - Evaluation/update of the following quantities has been requested:
2024-11-10 19:12:01.458769 info:Â Â Strains
2024-11-10 19:12:01.458769 info:Â Â In-plane stresses s1, s2, s12
2024-11-10 19:12:01.458769 info:Â Â Interlaminar shear stresses s13 and s23
2024-11-10 19:12:01.458769 info:Â Â Maximum strain failure criteria
2024-11-10 19:12:01.458769 info:Â Â Maximum stress failure criteria
2024-11-10 19:12:01.458769 info:Â Â 2D Tsai-Wu failure criteria
2024-11-10 19:12:01.458769 info:Â Â 2D Tsai-Hill failure criteria
2024-11-10 19:12:01.458769 info:Â Â 2D Hashin failure criteria
2024-11-10 19:12:01.458769 info:Â Â 2D Puck failure criteria
2024-11-10 19:12:01.458769 info:Â Â 2D Cuntze failure criteria
2024-11-10 19:12:01.458769 info:Â Â Sandwich core shear criteria
2024-11-10 19:12:01.463904 info:Â Â Â Active layered elements: 5670
2024-11-10 19:12:01.463904 info:Â Â Â Active solver elements: 0
2024-11-10 19:12:01.463904 info: - Start computation (5670 element(s) selected)...
2024-11-10 19:12:01.463904 info:Â Â Â Â 10% finished (568 of 5670)
2024-11-10 19:12:01.463904 info:Â Â Â Â 20% finished (1136 of 5670)
2024-11-10 19:12:01.473412 info:Â Â Â Â 30% finished (1704 of 5670)
2024-11-10 19:12:01.475431 info:Â Â Â Â 40% finished (2272 of 5670)
2024-11-10 19:12:01.475431 info:Â Â Â Â 50% finished (2840 of 5670)
2024-11-10 19:12:01.475431 info:Â Â Â Â 60% finished (3408 of 5670)
2024-11-10 19:12:01.483447 info:Â Â Â Â 70% finished (3976 of 5670)
2024-11-10 19:12:01.485860 info:Â Â Â Â 80% finished (4536 of 5670)
2024-11-10 19:12:01.485860 info:Â Â Â Â 90% finished (5104 of 5670)
2024-11-10 19:12:01.491876 info:Â Â Â Â 100% finished (5670 of 5670)
2024-11-10 19:12:01.493884 info:Â Â done for 5670 elements.
2024-11-10 19:12:01.562213 error: Failure criteria evaluation failed: NaN values detected. This is an internal logic error, please report this to the ACP developers.
2024-11-10 19:12:01.586149 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:12:01.596168 info: - File size: 44.125 MB
2024-11-10 19:12:01.596168 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:12:01.596168 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:12:01.608682 info: - Analysis type: 0
2024-11-10 19:12:01.608682 info: - Number of data sets: 9
2024-11-10 19:12:01.697381 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:12:01.712517 info: - File size: 44.125 MB
2024-11-10 19:12:01.712517 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:12:01.714292 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:12:01.725712 info: - Analysis type: 0
2024-11-10 19:12:01.726057 info: - Number of data sets: 9
2024-11-10 19:12:01.739008 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:12:01.742242 info: - File size: 44.125 MB
2024-11-10 19:12:01.742242 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:12:01.742242 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:12:01.762801 info: - Analysis type: 0
2024-11-10 19:12:01.762801 info: - Number of data sets: 9
2024-11-10 19:12:01.775456 info: Check Ansys RST file \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:12:01.786512 info: - File size: 44.125 MB
2024-11-10 19:12:01.786512 info: - Identified valid Ansys RST file with little endian byte-order.
2024-11-10 19:12:01.786512 info: Extract Ansys result set information from \users\username\Windows.Documents\Desktop\ATT2Y_AXIS\LEAP AUS\LEAP-AUS-TEST_files\dp0\SYS\MECH\file.rst
2024-11-10 19:12:01.793105 info: - Analysis type: 0
2024-11-10 19:12:01.793105 info: - Number of data sets: 9
November 22, 2024 at 9:46 am
Ashish Khemka
Forum ModeratorHello,
I see that your post is marked as answered. Did you get an answer? If yes then can you please share the solution here on forum.
Thanks,
Ashish Khemka
5649
1885
1404
1303
