November 9, 2020 at 2:11 pmrafaSubscriber
I am trying to do a 4 point bending test for the structure shown.
I created the material using ACP pre and input it into Ansys Static Structural for further analysis.
Unfortunately a solver pivot error popped up as shown in figure. I do not understand how exactly to solve it. Please help
November 10, 2020 at 1:44 pmKarthik RemellaAdministratorHello This is a duplicate post. Please refrain from creating duplicate posts to ensure a streamlined support. We will be responding to your question here (link below).
I'm closing this post.
Thank you.
Karthik
Viewing 1 reply thread- The topic ‘A solver pivot error while solving for composites structure’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Problem with access to session files
- Ayuda con Error: “Unable to access the source: EngineeringData”
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- Geometric stiffness matrix for solid elements
- How to select the interface delamination surface of a laminate?
- How to apply Compression-only Support?
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- SMART crack under fatigue conditions, different crack sizes can’t growth
Top Contributors-
1191
513
488
225
209
Top Rated Tags© 2024 Copyright ANSYS, Inc. All rights reserved.
