February 1, 2021 at 12:51 pmEyobMesseleSubscriber
Hello everyone,
In Ansys ATC, there is an Additive Manufacturing workbench and this workbench is suitable for Powder Bed Fusion work. All the basic laser process parameters are well addressed on the machine parameter settings. However, laser power is not addressed in the machine parameter settings. Without laser power, the powder material will not melt. So, I need to write some codes on the laser power and insert this code on the analysis settings, but I have no background about the writing codes. Can you give me a direction? For a better understand, here I attached the machine parameter dialogue box.
Thank you very much for your cooperation!
February 3, 2021 at 10:47 pmJohn DoyleAnsys EmployeeIn WB-Mechanical, we use a Lumped Layered approach to simulate the AM material deposition. You can read more about this in the Additive Manufacturing Analysis Guide. https://ansysproducthelpqa.win.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/add_ag/add_ag_AM_in_WB.htmlnThe load applied is temperature, not heat, and not at the local level (i.e. laser path). Below is an illustration of the process. The assumption is that the process parameters for the build have been set appropriately so that (1) the developed temperature is always at or above melt (no lack of fusion) and (2) the developed temperature does not greatly exceed melt (no keyholing).nnFebruary 4, 2021 at 1:05 pmEyobMesseleSubscriberDear thank you very much for your cooperation. The link is not worked, can you send me again?nFebruary 10, 2021 at 10:14 pmJohn DoyleAnsys EmployeeDo you have access to the on-line help documentation? I am just referring to the Additive Manufacturing Analysis Guide.nnFebruary 11, 2021 at 6:14 amEyobMesseleSubscriberDear,I have not online access.nJanuary 30, 2023 at 11:48 ammian imranSubscribersir, I am facing the same kind of problem. laser power is an effective parameter and including it not in the machine setting is a little bit strange. I will be happy if you guide me on how I can include laser power in that machine setting.best regardsÂ
Viewing 5 reply threads- The topic ‘Ansys-Additive Manufacturing Workbench-Laser power parameter’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- Frictional No separation contact
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
- Element has excessive thickness change, distortion, is turning inside out
Top Contributors-
1411
599
591
555
366
