December 13, 2020 at 10:50 ammurarzSubscriberHello everyone,I've been using ANSYS Fluent student version. There is an available surface combustion model - multiple surface reaction model which calculates the rate of particle surface species depletion (kg/s) for a given heterogeneous reaction. My question is, can I see this variable in the results? In the contours, there are kinetic rates of reactions, but I guess it is not the same?.I would appreciate any help,nThanks in advancen
December 17, 2020 at 11:36 pmRKAnsys EmployeeHello, nYou could create a custom field function for the rate of particle surface species depletion and then plot it in contours. n
December 18, 2020 at 11:12 pmmurarzSubscriberThis is an idea. Thank you.n
- The topic ‘Surface combustion – reaction rate from heterogeneous reactions’ is closed to new replies.
Ansys Innovation Space
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Fluent fails with Intel MPI protocol on 2 nodes
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- Help: About the expression of turbulent viscosity in Realizable k-e model
- Cyclone (Stairmand) simulation using RSM
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Facing trouble regarding setting up boundary conditions for SOEC Modeling
- Script Error
- convergence issue for transonic flow
624
599
591
366
