Topics relate to Fluent, CFX, Turbogrid and more
Surface combustion – reaction rate from heterogeneous reactions
    • murarz
      Hello everyone,I've been using ANSYS Fluent student version. There is an available surface combustion model - multiple surface reaction model which calculates the rate of particle surface species depletion (kg/s) for a given heterogeneous reaction. My question is, can I see this variable in the results? In the contours, there are kinetic rates of reactions, but I guess it is not the same?.I would appreciate any help,nThanks in advancen
    • RK
      Hello, nYou could create a custom field function for the rate of particle surface species depletion and then plot it in contours. n
    • murarz
      This is an idea. Thank you.n
  • The topic ‘Surface combustion – reaction rate from heterogeneous reactions’ is closed to new replies.
