October 9, 2020 at 1:08 pm
rmadams
SubscriberTrying to run the uninstaller (have tried via script and manually) and get a message that it detects that the uninstaller is already running. I have restarted with the same result and also tried several computers.nnAnyone else run into this?n -
October 12, 2020 at 2:47 pm
ANSYS_MMadore
Forum ModeratorArray How did you try to uninstall? Did you use Windows -> Programs and Features, or did you try running the files from C:\Program Files\AnsysEM\Uninstall ?n -
October 13, 2020 at 12:41 pm
rmadams
SubscriberI am running from C:\Program Files\AnsysEM\Uninstall. The goal is to send a script to uninstall remotely, but I have tried running the uninstaller manually from this folder as well. n -
October 13, 2020 at 12:48 pm
ANSYS_MMadore
Forum ModeratorCan you try:n C:\Program Files\AnsysEM\AnsysEM19.2\Win64\Uninstall\setup.exe /runfromtemp /z suppressconfirmation /removeonlyn -
October 13, 2020 at 3:10 pm
rmadams
SubscriberHi,nThat is what we are using - we have tried with and without the /runfromtemp. Still getting the message that it detects that the uninstaller is already running. This happens after rebooting as well (and we just run the uninstaller by hand).nnThanks!n -
October 13, 2020 at 7:47 pm
randyk
Forum ModeratorHi,If you look in Windows task manager -> Details tab. Do you see a setup.exe process running?nIn Windows Add/Remove Programs, is ANSYS Electronics Suite 19.2 listed?nPlease confirm, the exact message being displayed.nn
Viewing 5 reply threads
- The topic ‘Ansys 19.2 EM Uninstaller Wont Run’ is closed to new replies.
1305
