Ansys Products
Ansys Products
Is it possible to shear elements in static structural
    • batuhanozmen98
      Hello all
      I have a cutting case and I am not sure if I can solve this problem in static structural
      Cutting time is happening between 0.1 - 0.05 sec
      There is a cutting block which is moving 10 mm X and 10mm Y direction in the cutting time (So I have a displacement for this block)
      There is a fixed block.
      There is a profile (piece) which will be cutted in half by moving block
      I tried to solve it but It is stopping when my cutting block touches the profile(piece)
      Large deflection: ON
      Contact between piece and blocks defined one by one with Friction = 0.5
      Mesh type is for nonlineer analysis
      Materials from General Nonlineer materials (AL for piece and steel NL for Blocks)
    • Armin
      For applications involving short durations, significant nonlinearities, and element erosion, I recommend using explicit dynamic analysis with Ansys LS-DYNA. You can find more information about explicit dynamics theory in this free Ansys course: Explicit Dynamics Theory - Ansys Innovation Course - YouTube
