March 5, 2020 at 11:12 ambobdSubscriber
Dear,Â
currently i'm trying to do a simulation of a fluent where the temperature is rising due to a polymerization reaction.
For the temperature profile of the fluid I have written the UDF as follows;
I have implemented this udf as the temperature of the inlet. But during my simulation the temperature of my fluid won't change. And after a couple of time steps I receive a floating point error.
Is there someone who can help me?Â
Kind regards,
Bobd
March 6, 2020 at 3:40 pmRobForum Moderator
Turn off the UDF and see if the model runs without it. Â
March 6, 2020 at 3:44 pmbobdSubscriberYes, it works without the UDF
March 9, 2020 at 4:44 pmKarthik RemellaAdministrator
Hello,Â
Since you are using a mathematical expression as a boundary condtion, could you please see if you are able to use Fluent Expressions to resolve your issue? You might be able to entirely circumvent the UDF issue.
Hope this helps.
Best,
Karthik
- The topic ‘temperature change fluid’ is closed to new replies.
- Non-Intersected faces found for matching interface periodic-walls
- Script error Code: 800a000d
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- Help: About the expression of turbulent viscosity in Realizable k-e model
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- error udf
- Diesel with Ammonia/Hydrogen blend combustion
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
1311
591
569
525
366
