January 10, 2025 at 10:01 amnicholas.bizinosSubscriber
Trying to find out how to visualise pathlines across all periodic instances. I have found the periodic instances option in View - Display - Periodic Instances , but this only provides the option to show the boundaries. Not the pathlines or other result visuals. Is this possible? Could anyone assist?
January 10, 2025 at 10:48 amRobForum Moderator
Rotational should work, I think translational is in being looked into.
January 10, 2025 at 10:50 amnicholas.bizinosSubscriber
Thanks Rob, I am indeed looking for rotational but not sure how to apply it. Are you able to assist?
January 10, 2025 at 11:12 amRobForum Moderator
It should be in the Views once you've got the object created. I'll double check. We're very limited on what we can support on the public forum due to Export Law restrictions.
January 10, 2025 at 11:23 amnicholas.bizinosSubscriber
Oh, I found a solution on our customer support space. Was actually not aware of this facility. In any case it there does not seem to be a direct solution but seems to be a workaround, rotating mesh, appending case and data, fusing and repeating for all instances. A little bit of a mission unless there is a better solution in later release?
January 10, 2025 at 11:34 amRobForum Moderator
No, the repeats are supposed to take pathlines too. It's been a while since I last tried rotational periodic so it's possible the Object approach broke something. Hence needing to check.
January 10, 2025 at 12:09 pmRobForum Moderator
It looks like the Pathline Objects aren't being picked up by the periodic instancing. I'll raise internally.
January 11, 2025 at 3:46 am
January 13, 2025 at 11:01 amRobForum Moderator
Yes, it's been flagged. The pathline object isn't picked up by the periodic graphics tools.
- Workbench license error
- Unexpected error on Workbench: Root element not found.
- access to path files denied error
- Unexpected issues with SCCM deployment of Ansys Fluids and Structures 2024 R1
- AQWA: Hydrodynamic response error
- Tutorial or Help for 2 way FSI
- Questions and recommendations: Septum Horn Antenna
- Unable to connect to the license
- Moment Reaction probe with Large deformation
- Ansys with Vmware and CPU configuration : I’m lost, good practice?
1882
802
599
591
366
