January 3, 2025 at 6:23 pm
huizhelucyzhao
SubscriberHi,
I am running a simple modal analysis. A number of my bonded contacts are showing crazy penetration in the mode shapes. I ran contact analysis and the problematic contacts are shown as "closed" with zero penetration and zero gap in the analysis (so they should be good). Please see the images below and let me know how to fix this problem in the modal analysis.
Initial contact analysis shows everything is good:Â
Mode shape showing crazy penetration (the circled section should be concentric cylinder midsurface (thickness effect on) bonded together, but they've fully separated in the mode shape):
The above is mode 1, viewed on true scale.
Thanks
January 3, 2025 at 8:28 pm
huizhelucyzhao
SubscriberI received help from Ansys. It turns out MPC was not detecting contacts between shell and solid. Switching to Augmented Lagrange formulation for these contacts solved the issue.
- At least one body has been found to have only 1 element in at least 2 directions
- Script Error Code:800a000d
- Element has excessive thickness change, distortion, is turning inside out
- Elastic limit load, Elastic-plastic limit load
- Image to file in Mechanical is bugged and does not show text
- Help to do quasistatic analysis in static structural module
1932
839
599
591
366
