Ansys Products
Ansys Products
Unable to display Mesh Statistics Window in Turbogrid
    • nk583
      I am using Turbogrid for meshing a pump but the display for Mesh Statistics (Under Mesh Analysis) does not show up. Normally a separate window will pop up but in Turbogrid 2023 R2 I am not seeing a window pop up.
      Any help would be great!
    • V.P
      This can be a graphics error. You can try deleting the folder with the name .cfx, which is inside the "C:\Users\username" directory in Windows. Before deleting, please make sure to close the workbench session. After deleting, reopen the workbench session and the issue should be fixed.
    • nk583
      Brilliant! Thanks that worked perfectly!
