November 28, 2024 at 1:43 pm
Chris_g
SubscriberHi,
I am developing a 2-way coupled Rocky-Fluent simulation including gas-particle reactions using a custom module. I am wondering how to include reaction heat and to account for the enthalpy of released gases. According to the manual I have the following functions: add_heat_transfer/set_heat_transfer, add_explicit_fluid_heat_transfer_rate, add_implicit_heat_transfer_rate
From my understanding the "add/set_heat_transfer" functions only affect the particle temperature. What about the add_explicit/implicit_fluid_heat_transfer_rate? Do they only provide a source term to fluent or do they also influence the particle energy equation? What is the difference between explicit and implicit heat transfer?
Thanks for your help!
November 28, 2024 at 7:49 pm
Lucas Bertollo Baggio
Ansys EmployeeHello,
You are correct. The
_heat_transfer only affects the particle energy equation. The add_ _heat_transfer_rate provide a heat source to Fluent. The heat source is usually computed as S = Beta * (Tp - Tg), where Beta is the heat transfer coefficient, and T_p and T_g are the particle and fluid temperature, respectively. The explicit part will be obtained from Beta * Tp and implicit part is Beta itself since we don't know the fluid temperature of the cell in which the source term will be applied to. This information is still on Fluent's side.Â
Best regards,
Lucas
December 12, 2024 at 11:37 am
Chris_g
SubscriberThank you for the information!
What values do these functions expect?
I've set up some test cases with a single particle. When I pass nondimensionalized 10W (or 100/1000) with add/set_heat_transfer I get 5-20 Watts more when I evaluate Sum:Solid Explicit Heat Transfer Rate*CellVolume and Particle temperature (m*cp*dT)
For add_explicit_heat_transfer_rate I can't seem to get realistic values whether I pass nondimensionalized Joule, Watt or Watt/cell Volume
January 9, 2025 at 2:40 pm
Chris_g
SubscriberI finally figured it out by running several tests. The add/set_heat_transfer requires Watt (nondimensionalized).
The add_explicit_heat_transfer_rate requires (nondimensionalized) Joule. However, it must be kept in mind, that the function works at particle time scale so if values are converted from Watt to Joule they must be multiplied by the particle time step.
- affinity not set
4177
1487
1363
1194
