March 28, 2024 at 3:12 pm
jwm84
SubscriberI am running my Fluent case on a HPC linux server in batch mode. I am using the following line in my .sh script file to include graphics in Fluent.Â
fluent 3ddp -nogui -gu -driver null -t $SLURM_NTASKS -cnf=$NODEFILE -mpi=intel -pinfiniband -sifile=./"$SLURM_JOBID"_fluentServer2.txt -i $ansysFile.jou > kinetics_model_reacting.txt
The -gu -driver null options should enable me to create and save animations on the cluster. However, I am unable to do this. I am creating animations and changing their frequency using the following TUI commands. I have verified that the TUI commands are correct by inputting them in my local case setup.
/solve/animate/objects/create temp-animation_dist animate-on core_temp storage-dir "." q  ; creating animations on the contour named "core_temp"
/solve/animate/objects/edit temp-animation_dist frequency 200 q ; change the frequency of writing files
Note that I am able to output animations if I had already set them up in my local case file. However, I am unable to set up new animations on the cluster.
April 11, 2024 at 11:03 am
Rahul
Ansys EmployeeHelloÂ
Is it throwing any error while creating animations with this TUIÂ commands?
April 13, 2024 at 5:46 pm
April 15, 2024 at 9:09 am
Rahul
Ansys EmployeeCould you please also share the transcript to understand the error?
April 15, 2024 at 12:45 pm
jwm84
SubscriberHi,
I don't understand what you mean by transcript. Do you want the output file or do you want the journal file?
The output file throws the error that I showed above.
April 15, 2024 at 12:50 pm
Rahul
Ansys Employeeyes, the content of output file.
- The topic ‘Unable to create animations for batch jobs in a HPC cluster’ is closed to new replies.
4618
1530
1386
1210
