Received signal SIGSEGV
    • Jason Huang
      I received this error when reopening my previously saved case file in Fluent. Basically, I can get the result data with this case file when I set everything up the first time, but I receive this error every time when I reopen this case file. This case can be read and simulated on my friend's PC. Therefore, I believe my geometry and mesh are fine, and it might be my computer's problem. By the way, I can run other cases with my Fluent and I didn't use any user-defined function. Can someone help me out?
      Thanks.
      Here is the error message below:
      Node 999999: Process 66448: Received signal SIGSEGV.
      = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
      = RANK 0 PID 17188 RUNNING AT ROG-PC
      = EXIT STATUS: -1 (ffffffff)
      = RANK 1 PID 28140 RUNNING AT ROG-PC
      The fl process could not be started.
    • Federico
      you said this case can be run on your friend's PC, are they also able to read the .dat file?
      Which version of Fluent are you using?
      • Jason Huang
        Thanks for your reply. We are both using 2023R1. Because the data file is too large, I just shared the case file, but he can read and run the simulation.
        • Federico
          Are you able to read the case file without the data? I'm trying to isolate the source of the problem.
    • Jason Huang
      Nope, I cannot read my case file. It will give this error with or without the data file. But I can read other case files from my friend. It looks like my software cannot read the case files that were produced and saved from my local software. So, I think there are some reading problems with my software.
      • Federico
        What version of Fluent are you using? And what is the output format of the case file? .cas/.cas.h5/.cas/gz?
    • Jason Huang
      I'm using Fluent 2023R1 and Workbench 2023R1. The output file is cas.h5.
      • Federico
        From a clean state, meaning after running the case from your machine, can you try to write the case and solution data in uncompressed format .cas/.dat (just change the file type when you write the files, File > Write > Case & Data).
        Then see if you can read these new files.
    • Jason Huang
      I just set everything up and wrote my case in .cas format. But I still got that error.
Viewing 4 reply threads
  • The topic ‘Received signal SIGSEGV’ is closed to new replies.
