September 5, 2023 at 10:01 amSai Manikanta KajaSubscriber
HI, I am trying to write a matrix to a file using UDF, teh below is loop is used in customisation manual
compute_node_loop_not_zero(i)
in the example, It says, we can know more about it by refering to para.h
I am unable to rech to documentation of the same. Please help me how to read about the same.
Thank you -
September 5, 2023 at 2:49 pmNikhil NAnsys Employee
I think this is referring to the 'para.h' file in the Fluent's directory.Â
September 6, 2023 at 4:42 amSai Manikanta KajaSubscriber
May I know how can I access the same ?Â
September 7, 2023 at 9:06 amNikhil NAnsys Employee
You can find this file within the directory of your locally installed Ansys products, specifically Fluent, on your system. You can use the search in the File Explorer.Â
- The topic ‘para.h in UDF’ is closed to new replies.
Ansys Innovation Space
- Non-Intersected faces found for matching interface periodic-walls
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- Help: About the expression of turbulent viscosity in Realizable k-e model
- Cyclone (Stairmand) simulation using RSM
- error udf
- Diesel with Ammonia/Hydrogen blend combustion
- Fluent fails with Intel MPI protocol on 2 nodes
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script error Code: 800a000d
- Encountering Error in Heterogeneous Surface Reaction
513
488
225
209
