July 31, 2023 at 4:46 pmMepalSubscriber
Hello all,
I've just faced a problem about a license below when I started Fluent:
Connected License Server List:
ANSYS LICENSE MANAGER ERROR:Insufficient CFD Solver - Level 1 licenses available.
Dependent feature cfd_solve_level1 in AND keyword is not available.
I'm sure I've never modified or adjusted any license file in the software because I use the university desktop.
Can anyone suggest me what is the sourse of this problem, or what should I do to fix it? -
August 1, 2023 at 10:23 amRobForum Moderator
That looks like all licences are in use, are you running with a local licence or one from the Campus network?
August 1, 2023 at 11:36 amMepalSubscriber
I use the campus network.
August 1, 2023 at 1:06 pmRobForum Moderator
I think someone else is using the licences - if you try now does it work?Â
- The topic ‘License error with Fluent 2022 R2 (Academic license)’ is closed to new replies.
Ansys Innovation Space
- Workbench license error
- Unexpected error on Workbench: Root element not found.
- Unexpected issues with SCCM deployment of Ansys Fluids and Structures 2024 R1
- AQWA: Hydrodynamic response error
- Questions and recommendations: Septum Horn Antenna
- access to path files denied error
- Tutorial or Help for 2 way FSI
- Unable to connect to the license
- Moment Reaction probe with Large deformation
- Ansys with Vmware and CPU configuration : I’m lost, good practice?
624
599
591
366
