June 30, 2023 at 8:54 pmsg.studentSubscriber
I am a newer student and I have a question about how to code in commands or APDL script. I am not proficient at all and I have been looking in all the forums and help pages but I can not figure it out.
I want to run a simulation until it the simulation is complete and then I want to delete elements and continue the simulation where it finished. I want to continue off on the last step of the build with deleted elements to see how the build's stress will increase. Is this possible and, if so, how would I code this?
Thank you
July 2, 2023 at 12:54 ampeteroznewmanSubscriber
The method is to use the EKILL command to remove elements and then continue the solution in the next step.
Type that word into the Search bar at the top of this page to find many links to discussions on this command.
- The topic ‘Restarting simulation after deleting elements.’ is closed to new replies.
- Ayuda con Error: “Unable to access the source: EngineeringData”
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- Image to file in Mechanical is bugged and does not show text
- Timestep range set for animation export
- Frictional No separation contact
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
1316
591
569
525
366
