June 29, 2023 at 1:00 pmLevente BicskeiSubscriber
Dear Forum,
I would like to create a simple sample simulation of cryogenics cooling. Just a pipe with one inlet, one outlet.
How can I create a new material in the temperature range of 10-50 K?
I tried copying an existing gas and manually modifying the material properties, but it seemed to only work down to 100 K. From measurements I have the data-points for temperature-viscosity, temperature-density, etc pairs. I want to create a new material from these, but I only saw polynomial options in the basic ansys material data file.
Otherwise, I have 40 pairs of points (10-50 K with 0.1 K step size)
Thank you for your help!
June 30, 2023 at 11:42 amPrashanthAnsys Employee
That is very high no of data points. Easy way would be to curve fit the graph in excel (or matlab etc.) and get a polynomial of some order. Input that polynomial to the material panel.Â
June 30, 2023 at 12:12 pmLevente BicskeiSubscriber
June 30, 2023 at 12:25 pmPrashanthAnsys Employee
I think the values here are just to visualize the graph, at different ranges. It's okay if it defaults to a value.
- The topic ‘Cryogenics Simulation’ is closed to new replies.
- Non-Intersected faces found for matching interface periodic-walls
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- Help: About the expression of turbulent viscosity in Realizable k-e model
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- error udf
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- Facing trouble regarding setting up boundary conditions for SOEC Modeling
- UDF, Fluent: Access count of iterations for “Steady Statistics”
1406
599
591
555
366
