The Ansys Innovation Space website recently experienced a database corruption issue. While service has been restored there appears to have been some data loss from November 13. We are still investigating and apologize for any issues our users may have as a result.
Cryogenics Simulation
    • Levente Bicskei
      Dear Forum,
      I would like to create a simple sample simulation of cryogenics cooling. Just a pipe with one inlet, one outlet.
      How can I create a new material in the temperature range of 10-50 K?
      I tried copying an existing gas and manually modifying the material properties, but it seemed to only work down to 100 K. From measurements I have the data-points for temperature-viscosity, temperature-density, etc pairs. I want to create a new material from these, but I only saw polynomial options in the basic ansys material data file.
      Otherwise, I have 40 pairs of points (10-50 K with 0.1 K step size)
      Thank you for your help!
    • Prashanth
      That is very high no of data points. Easy way would be to curve fit the graph in excel (or matlab etc.) and get a polynomial of some order. Input that polynomial to the material panel.
    • Levente Bicskei
      Dear Prashanth,
      But every time I input the polynomial coefficients and modify the min-max range the curve seems right, but after I close Polynomial Profile tab and open it again, it goes back to the default 300-500 K range.
      Will it be still okay even though the min-max values changed?
      Thank you!
    • Prashanth
      I think the values here are just to visualize the graph, at different ranges. It's okay if it defaults to a value.
  • The topic ‘Cryogenics Simulation’ is closed to new replies.
