June 27, 2023 at 6:02 pm
June 28, 2023 at 12:15 pm
Supreetha J
Forum ModeratorHello,
Could you please check if there is enough space, memory or permission to access the file you are trying to load?
Thank you. -
July 2, 2023 at 8:59 pm
edeng80
SubscriberThanks for your answer Supreetha J
I check about space, and memory, and it was ok. I finally solved by unnistalling and installing Fluent again.
Thanks for your support.
- The topic ‘Help while opening file: sopeninputfile: unable to open file for input’ is closed to new replies.
Ansys Innovation Space
- affinity not set
1414
1241
1118
1015
