TAGGED: ansys-aqwa, aqwa, csv, expert-parameters, export
June 6, 2023 at 9:21 am
Eugenio Baita Saavedra
Subscriber -
June 7, 2023 at 3:54 pm
Mike Pettit
Ansys EmployeeHello Eugenio,
Please refer to the answer here: AQWA – Export DATA CSV File (ansys.com). The post-solve command to run AqwaReader will be executed for each design point. I'm afraid this is the easiest way to export CSV result files from a parameter study at the moment.
Alternatively, you can check the Retain option for each design point in the Table of Design Points, and then go into each design point (i.e. Set as Current) and export the CSV result files one-by-one.
Cheers, Mike
- The topic ‘Export results when using parameters AQWA’ is closed to new replies.
1587
1386
1242
