October 4, 2017 at 12:20 pmpglAnsys Employee
How to perform rigid translation an existing mesh inside APDL?
October 17, 2017 at 10:25 amArunAnsys Employee
First use CS or CSKP command to create a local coordinate system. Then use TRANSFER command to move the mesh.
- The topic ‘Perform rigid translation an existing mesh inside APDL’ is closed to new replies.
Ansys Innovation Space
- Ayuda con Error: “Unable to access the source: EngineeringData”
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- Image to file in Mechanical is bugged and does not show text
- Timestep range set for animation export
- Frictional No separation contact
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
591
569
525
366
