July 4, 2022 at 4:55 ammathansambuSubscriber
Hi to all,
Currently i working in Flow induced vibration on cantilver beam. I successfully completed the FSI 2-way using system coupling method in workbench.
Now im having issue on how to transfer the surface pressure made by the flow (fluent) to Transient (C-Beam) and obtain the harmonic response created from there.
As in external source tutorials, able to connect transient solution to Fluent result, but im not able to link up either since im using ANSYS 2021-R2.
Hoping that any experts can guide me on this issue? -
July 7, 2022 at 7:29 pmKarthik RemellaAdministrator
How did you set up your FSI data transfers? Could you please provide a screenshot?
Karthik
July 18, 2022 at 1:58 am
July 22, 2022 at 2:45 pmmathansambuSubscriber
Hi everyone,
Anybody can assist / guide me on this matter.
Thank you.
- The topic ‘FSI 2-way Method – Post processing’ is closed to new replies.
Ansys Innovation Space
- Non-Intersected faces found for matching interface periodic-walls
- Script error Code: 800a000d
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- Help: About the expression of turbulent viscosity in Realizable k-e model
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- error udf
- Diesel with Ammonia/Hydrogen blend combustion
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
599
591
540
366
