March 25, 2022 at 1:58 pmTomPhemmySubscriber
In ANSYS Mechanical, the default cross section mesh for beams with circular cross section is 8 divisions along the circumference and 2 divisions along the radius as shown below :
March 29, 2022 at 12:51 pmRahul KumbharAnsys EmployeeI assume you are okay using APDL commands In Mechanical. You can insert command object under the line geometry and add the coomands to change the secdata.
March 29, 2022 at 12:55 pmTomPhemmySubscriberthank you for this information. I have noticed that this works. But why does ANSYS Mechanical not render the new section like APDL does?
March 29, 2022 at 12:58 pmRahul KumbharAnsys EmployeeThe reason is these commands are executed while solving in background not in GUI.
March 29, 2022 at 1:00 pmTomPhemmySubscriberGood to know; thank you.
Viewing 4 reply threads- The topic ‘Mesh the cross section of a beam in ANSYS Mechanical’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Problem with access to session files
- Ayuda con Error: “Unable to access the source: EngineeringData”
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- Geometric stiffness matrix for solid elements
- How to select the interface delamination surface of a laminate?
- How to apply Compression-only Support?
- Timestep range set for animation export
- SMART crack under fatigue conditions, different crack sizes can’t growth
- Image to file in Mechanical is bugged and does not show text
Top Contributors-
1191
513
488
225
209
Top Rated Tags© 2024 Copyright ANSYS, Inc. All rights reserved.
