TAGGED: homogeneous, multi-phase-flow, udf-macro, volumetric-reaction
May 4, 2021 at 4:16 amHesam062Subscriber
Hi
when we are using UDF for volumetric reaction, will defined values for reaction parameters like rate exponent, Arrhenius rate,... through Fluent GUI affect the reaction rate?
Thanks for your time!
May 4, 2021 at 12:46 pmRKAnsys EmployeeHello Once UDF is initialized, it over writes values previously set through GUI
May 4, 2021 at 4:09 pmHesam062SubscriberThanks!
Viewing 2 reply threads- The topic ‘Specification of homogeneous (volumetric) reaction rate?’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Non-Intersected faces found for matching interface periodic-walls
- Script error Code: 800a000d
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- Help: About the expression of turbulent viscosity in Realizable k-e model
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- error udf
- Diesel with Ammonia/Hydrogen blend combustion
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
Top Contributors-
1351
599
591
540
366
