Numerical Results - Lesson 7
In this lesson, you will learn how to:
- Look at the lift and drag forces on the wing
- Look at the lift and drag coefficients on the wing
- Create pressure and Mach contours
- Look at the Boundary Layer before and after the shock
- Create velocity vectors at the trailing edge plane
- View trailing vortices
- Plot Pressure Coefficient at spanwise fraction .2
- Compare Fluent Pressure Coefficient to experimental data
