In this blood flow in 3D bifurcating artery simulation, we have included most of the physical properties, such as the non-newtonian fluid properties of blood and the pulsatile nature of the flow. However, in order to perform a simulation closer to the real scenario, elastic wall features should be included. This can be done by coupling the solution from FEA simulation and CFD simulation in Ansys Workbench. It is also always good to compare the results obtained from simulations with experimental results. In this case, however, we do not have experimental data based on the exact same geometry.
