Numerical Solution
Watch the following video for demonstrations:
Summary for the video:
- Monitors → Create → Drag → Print to Console → wall_artery
- Solution Initialization → Hybrid Initialization → Initialize
- Calculation activities → Create → Solution Data Export → Change File Type to "CFD-Post Compatible"
Quantities for export: Static Pressure, Total Pressure, Velocity Magnitude, x velocity, y velocity, z velocity, Wall Shear (* note that you need to export all three components of velocity in order to plot vector field in CFD-Post!) - Create → Particle History Export → File Type to CFD-Post → Select the injections → Choose to save directory
- Run Calculation → Time Step Size 0.01 → Number of time steps 50 → Max Iterations/time step 200 → Hit "Calculate"!
If you are using ANSYS 19.2, refer to the steps below:
- Setup → Reference values → Type in the values given in the above table
- Report Monitors → New → Force Report → Drag → wall artery
- Calculation Activities → Create → Solution Data Export
- Change the file type to “CDAT for CFD Post and Ensight”
- Select above-mentioned quantities for export
- Calculation Activities → Create → Particle Data History Export → Select both injections
- Run Calculation → Time Step Size(s) 0.01 → Number of Time Steps 50 → Maximum Iterations/Time Step 200 → Hit Calculate
Before running the calculation, you should also create a monitor for the inlet velocity so that we can check that the UDF is working correctly in the Verification and Validation step.
- Report Monitors → New → Surface Report → Area-weighted Average
- Set Field Variable as Velocity → Velocity Magnitude
- Select "inlet" under Surfaces
- Make sure to check the box next to Report Plot
- Give it a suitable name and click OK
