The Getting Started course offers you an introduction to the practical application of CAE-based sensitivity analysis, multidisciplinary optimization and robustness evaluation with Ansys optiSLang® process integration and design optimization software.
During the training you will be informed about the possibilities of process integration and variation analysis. By means of illustrative examples, sensitivity analyses and different optimization steps as well as their results will be explained and evaluated. Here, the focus is on the user-friendly application and operation of the software.
Learning Outcomes:
Following this training course, you will be able to:
- Introduction to Ansys optiSLang software and the graphical user interface.
- Automate manual simulation steps to conduct parametric variation analyses.
- Sensitivity analysis that helps you to understand your numerical task.
- Investigate parameter sensitivities, reduce complexity, and generate best possible meta models.
- Analysis of experimental data.
- Introduction to optimization goals and constraints.
- Response surfaces based and direct optimization.
- Single- and multi-objective optimization.
Cost: $450.00
- Course Duration: 2-4 HOURS
- Skill Level: Beginner
- Skills Gained: Parametric Variation Analyses, Sensitivity Analysis, Single and Multi-Objective Optimization
Recommended Learning Products
Premium
Optimization
Truck Suspension Optimization with Ansys Discovery in Ansys optiSLang Software (Workshop)
1-2 HOURS
Premium
Structures
Ansys nCode DesignLife Getting Started
2-4 HOURS
Premium
Structures
Hook Optimization with Ansys Mechanical in Ansys Workbench in Ansys optiSLang Software
1-2 HOURS
