March 17, 2023 at 9:00 am
FAQParticipantSFAC is used to calculate the time increment. In semi-implicit, program calculate a time increment that is stable and to be on safer side, multiply that time increment with this safety factor to get the time increment program is going to use. For example, if the stable time increment program calculates is tstable= 1sec and SFAC is 0.9 (default), then the program uses a time increment of timinc=0.9*tstable=0.9. If the SFAC is 0.1, then the time increment used will be 0.1*tstable=0.1. If the solution seems be be unstable, using a smaller factor of safety will help.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
