With regards to SECTYPE,,GENB option for beam cross sections, is it possible to associate this with kinematic plastic hardening.
Tagged: 2019 R1, materials, mechanical-apdl, plasticity, structural-mechanics
April 5, 2023 at 2:31 pm
FAQParticipantIsotropic hardening is the only assumed for the material response that is supported. If user cannot use regular beam cross sections, then the only workaround is to fully model the beam in 3D with conventional solid/shell elements.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- Guidelines of modeling a gasket.
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- Why is the unit of the elastic foundation stiffness N/m^3?
- How do I move a material property from Engineering Data to an existing Material Library?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
- How do I enter major Poisson’s ratio in ANSYS Mechanical?
