April 5, 2023 at 2:32 pm
FAQParticipantFor input problems like this, which produce a question mark next to the feature, the “Show Errors” button will tell you a little more information on what is missing. Following precautions should be taken for applying a moment in a cyclic symmetry model: 1. Z-axis of cylindrical coordinate system used for symmetry must be aligned with global Cartesian z-axis so model must revolve around global z-axis. This is only necessary for cyclic symmetry when applying a moment. So you must rotate your model. 2. Moment can only be scoped to a remote point. 3. The remote point must lie on the axis of symmetry, and can be scoped to anything but a vertex. 4. You should also add a remote displacement to fix the remote point in the other translational directions (not along symmetry axis), so it stays on the symmetry axis during deformation of the model. This is not a requirement, though.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
