Why when I introduce the semi implicit method, the convergence pattern change even before the solver switches from pure implicit to semiimplicit?
Tagged: 2019 R1, explicit-dynamics, General, mechanical, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantSemiimplicit command can overwrite other commands. The following commands are affected: 1.Nsub and deltim: During the explicit solve phase, the time incrementation does not follow the nsub and deltim commands 2.Etcon: If semiimplicit command is issued, etcon command is ignored. 3.Outres: During the explicit solve phase, the results files writing frequency specified in outres command is ignored unless a negative number is specified. 4.rescontrol: During the explicit solve phase, the results files writing frequency specified in outres command is ignored unless a negative number is specified.
