General
General
Why the total deformation plot does not measures correctly on scale ruler at the bottom GUI window?
    • FAQFAQ
      Participant
      This is due to sometimes when results are set to magnified scale. Check the scale of the results is set to true scale (factor =1). Also check for directional deformation plots. Total deformation will give only a positive number, where as directional deformation plot will reveal the behavior of deformation more explicitly.
