Why the section plane icon is grayed out in Mechanical windows ? How to make the section plane window re-appear ?
June 6, 2022 at 9:58 am
FAQParticipantThe section plane icon is grayed out when you reach the limit of 6 section planes defined. If the section plane window doesn’t appear, you should go in “View>Windows>Section Planes” to make it re-appear.
