Why the locations of replaced components from CAD application into Spaceclaim are different than the older one?
June 5, 2023 at 7:05 am
FAQParticipantThe issue appears when newly created parts in CAD application uses different workplane origin or coordinate system. Check the locations of new components in CAD tool first and compare it with the old parts. Correct the coordinate system of new components and then try importing again.
