Why the General Joint doesn’t have options for specific control of all Rotational DOFs (just like in translations) in a Rigid Dynamics model (RBD)?
March 17, 2023 at 9:00 am
FAQ
ParticipantThe general joint doesn’t allow individual rotation constraint on purpose. The problem is that while constraining a single rotation among 3 sounds meaningful when considering small rotation, this is ambiguous with large rotations. See the detailed explanation below: – Joints are usually used in the context of large rotations. – When you have large rotations, the 3 rotations are not defined as rotations around the reference coordinate system of the joint but as a sequence of 3 angles. – You apply the X rotation and define a new updated intermediate coordinate system. – You apply a Y rotation around this second coordinate system and define a new update third coordinate system. – You apply a Z rotation around this last CS. – The 2nd and 3rd CS have no physics that define their position, their position is only defined by the sequence of angles. – In short, 3D rotations are not following the same math as 3D vectors, and the 3 components are not independent of each other. Now imagine that you release 2 out of 3 axis – say X and Z. – While X is clearly defined as the X rotation about the reference CS, unfortunately, as the Y rotation is not defined, the very definition of the Z rotation is ambiguous. – That’s the reason why we don’t allow combination of two free DOFS. – In the case of small rotations, the rotations around the reference CS and the rotations around the update CS are almost the same, this you could free two rotations (but it is still blocked). ** Note: As a workaround, you can work at the velocity level. -The X, Y and Z components of the joint rotational velocity are a 3D vector, they are the 3 components of the rotational velocity of the mobile CS wrt the reference CS. -Because it is a regular vector – just like displacements – you can specify any combination of zero and non zero velocities. – You can use a joint that has 3 rotations, and put a joint driver that constraints the Y rotation.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
- Presentation on shock analysis using response spectrum and transient dynamics
